![](/styles/donate.gif)
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I bought kit b4 hand. Dealers item.Where did you get a 4 wheel kit that fast?
Hahahaha hahahaha Hahahaha hahahaha......too late!
Byam
7000km Stock tri-hub whit oem 4th wheel kit from the beginning .Stock tri-hub 7000km? no 4th wheel kit or anything?...
Seriously they did not even need grease but i changed them anyway....
Almost 20 000km whit AC or fake YAM sled, many different problems never whit the tri-hub whit 4th wheel kit
I was considering JT wheel kit but i think it will not fit whit racewrex rapid block. Maybe i am wrong
Byam
What is bad on the desing?They don't let go till around 5k miles. Most sidewinders aren't there yet. The bearings are now replaceable but it's still a bad design.
except for the small 6004. For sure i would like 6205 but i don't see any problem whit desing
![Dunno :dunno: :dunno:](/styles/default/xenforo/smilies/dunno.gif)
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
If one bearing goes bad it takes the whole rear end out. If it came with 3 wheels like every other sled in the universe it wouldn't be an issue. Also a chunk of ice going through there can break them. It's just a dumb place to try to shave a few pounds.
Doc Harley
- Oct 17, 2016
- Here & there
When the time comes to grease the tri-hub brgs. Which grease high or low temp? Sorry if it's a stupid question.
Doc Harley
- Oct 17, 2016
- Here & there
Is 1.75" ok for track tension?
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
2" is the spec at 20LB, I think you would be ok at 1.75"
Slide wear isnt much of an issue on these so a little tighter doesnt hurt.
