Tricky front shock on Attak
jlemieu1
Rosemount, MN
14 Viper LTX SE, 14 Viper LTX
Does anyone have a trick for getting at the top bolts on a front shock on an Attak? I'm may be starting to strip them. The area is so tight, do I need to remove all nose plastic and the bumper? Also is it a 14mm nut and bolt.
I just removed my 08 Vector shox, and although it was tight getting them out, I didn't have to remove any plastic.
Not sure what an 06 Attack is like, but I just used a stubby socket/ratchet and a box end 14mm ensuring a few times my socket was on straight/true.
Yep 14 mm. I just use a ratchet box end and a regular box end wrench. Ratchet wrenches (good ones) can be worth their weight in gold.
I just changed my shocks on my 06 Attak too. It's tight but it can be. Same as above on the tools.
I used woble extensions and an impact gun
