Tuned 998 idle AFR?
Okay thanks.. Time for a fuel pressure test.. I'm idling pretty rich, guessing I might have a newer pump like justinator was posting about. I'm in the mid to upper 11's on a new motor..
Jon I just looked at some old data logs from last winter on my 2020 with td tunes and my idle afr was 11.6-11.8 on a warm motor. The idle I logged was over a minute and this is where it stayed.
Good to here! Mine is just under that.. Thinking im good.. Only thing I thought might be off otherwise she was good all the way to the BAR.. I beat my buddy on his Cat 6000 by 1.4 gallons at the station.. Of course we might have been cruising at times around 80-90? LOL that 600 was working to keep up. Had to set the rings !
Stage 3 PEFI (280 HP) w D&D Tech2 muffler (= maybe 290+ HP):
12.1 to 12.5 AFR cold idle
At 180 deg F coolant temp = 13.8 to 14.2.
