Turboflash
- Mar 18, 2019
- Southern MN
I just installed an AEM AFR gage on a Stage 3 TCat. What should the hot idle AFR be?
When first started, the gage comes on line at 13.7. As it continues to run the AFR goes up and up and up until it goes out of range high side. The sled runs perfect in the test field beside my shop. It always has been a strong sled so I know the tune is good. Thanks!
NYTurbo
Phone your tuner
Fleecer
- Jun 13, 2014
- 2019 SRX
That's normal IMO, as my sled does the same, and my tune is from a different vender. Running low AFRs at 1/16 throttle is a waste of fuel IMO. They run lean up to 5-6000 rpm, and letting off the throttle in any range will permit numbers to climb as you state, but once throttle is applied again it should/will came back down within the spec.
Turboflash
- Mar 18, 2019
- Southern MN
Something is wrong because w this sled, it never comes back into range until I shut it off and let it cool a bit, then when re-started, it will be back in range but only like for a minute. AFR slowly climbs until its,out of scale again.
I think maybe sensor is bad. It's a Bosch LSU 4.9.
sideshowBob
I have had AEM system on my SW for over two years and have never seen the AFRs act like this with any tune or muffler combinations.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
change your wide band sensor, it should be anywhere from high 13's tho high 14's all in the no load cruising range or idle
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I typically see low to mid 13's at idle most all the time. I've never seen it that lean idling even.
Fleecer
- Jun 13, 2014
- 2019 SRX
Oh....I thought it came into range once applying throttle! To continue climbing is not right.Something is wrong because w this sled, it never comes back into range until I shut it off and let it cool a bit, then when re-started, it will be back in range but only like for a minute. AFR slowly climbs until its,out of scale again.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It's either your sensor or it's the power wire that is powering the gauge if you wired it in. Make sure your power source is a constant 12 volts no matter the rpm or the gauge will act just as you describe.
Turboflash
- Mar 18, 2019
- Southern MN
Sensor was bad.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
knew it.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Your running TD tunes? What you seeing for AFR idle?That's normal IMO, as my sled does the same, and my tune is from a different vender. Running low AFRs at 1/16 throttle is a waste of fuel IMO. They run lean up to 5-6000 rpm, and letting off the throttle in any range will permit numbers to climb as you state, but once throttle is applied again it should/will came back down within the spec.
Fleecer
- Jun 13, 2014
- 2019 SRX
At idle......12.4. Give it a smidge of throttle, goes up to 13.7. This is no load, idling in garage.knew it.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Okay thanks.. Time for a fuel pressure test.. I'm idling pretty rich, guessing I might have a newer pump like justinator was posting about. I'm in the mid to upper 11's on a new motor..At idle......12.4. Give it a smidge of throttle, goes up to 13.7. This is no load, idling in garage.
- 12K
