12pointer
- Nov 24, 2012
- OHIO
- 2015 Viper LTX SE blue and white-Ulmer clutching, 8dn belt, MBRP trail can, J&T 4th wheel kit, Shaper bars,
What are everyone running for carbides on there tuners. Thinking about switching to these skis. Are you all going by Yamaha chart or something different?. And are they really that much better??
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
i run dual 6" on my tuners along with a 4-2-4 stud pattern on my xtx but i've got power steering. i like them and they work really well for me, plus you can't beat the price.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I am running 4 inch all around and do not have studs.
12pointer
- Nov 24, 2012
- OHIO
I was thinking on running 6 inch on the insides and 2 inch on the out sides. Any thoughts ? anybody tried this combo??
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
I'm running 4 inside, 2 outside. 121 inch track with an Iceripper track. I believe that's Yamaha's recommendation.
I had tons of problems with darting at first but found that my skis weren't aligned or toed out properly and I took a little pressure off the front by letting the limiter strap out a little. It's still tighter than stock.
Only got one ride in after the changes last season but seems to tracking good now.
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
I am running 4 in inside and 2 in outside on a long track apex with 188 pics. Best way I improved my handleing was to remove stock skis and run the tunner ski! I struggled for two seasons to get my sled to go around a corner, now she is glued to the trail and predictable! My opinion
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
I run 6 inside and 4 outside works pretty good .Was thinking of tightening the strap one hole to see if it got better .
viper50
- Feb 8, 2009
- Webster NY
- 2012 Apex XTX
Bergstrom 8" triples on the inside, hard bar on the outside.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I'm running 6" on both and works great, with eps you don't know the difference
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
Just put my Tuners on tonight with the same 6/4 setup.
Gonna try them on Saturday and see how they feel. I left the stockers on for 300kms so looking forward to comparing.
snobill said:I run 6 inside and 4 outside works pretty good .Was thinking of tightening the strap one hole to see if it got better .
