maniac
sorry guys new to phaser if i close of tunnel with stock exhaust anything to worry about like melting plastic or seat also do i remove the plastic pieces on each side thanks
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Close off the rear hole to help with the ice build up. A lot of guys keep the front hole open. That is how the new phazers come. You should not have a problem with heat if you do it this way.
martin63092
close back hole remove plastic. buy the kit straight from yamaha it comes with extra heat protective thing, ask your dealer
Weapon X
closed off the back hole on my sled with the schmidt bros kit ( way cheaper than dealer ) and remove rear snow flap ,If It already hasn't ripped off by backing off of your truck and your snow build up problem is gone.
- Nov 1, 2009
- 2009 Phazer RTX
Weapon X said:closed off the back hole on my sled with the schmidt bros kit ( way cheaper than dealer ) and remove rear snow flap ,If It already hasn't ripped off by backing off of your truck and your snow build up problem is gone.
Removing the snow flap? is this only for installation or permanently?
spike337
Good question. You'd think it'd over heat for sure if you removed it.yamahas said:Weapon X said:closed off the back hole on my sled with the schmidt bros kit ( way cheaper than dealer ) and remove rear snow flap ,If It already hasn't ripped off by backing off of your truck and your snow build up problem is gone.
Don't know if that's the answer?
- Nov 1, 2009
- 2009 Phazer RTX
spike337 said:Good question. You'd think it'd over heat for sure if you removed it.yamahas said:Weapon X said:closed off the back hole on my sled with the schmidt bros kit ( way cheaper than dealer ) and remove rear snow flap ,If It already hasn't ripped off by backing off of your truck and your snow build up problem is gone.
yea thats what i was getting at. The snow deflects back onto the top of the track and hits the heat exchanger.
You could also just use a sheet of aluminum and rivit it to the tunnel, would be the cheapest way to go. Leave the front open to cool off under the gas thank and you will be good to go.
Weapon X
My sled has never overheated once I have a temp sticker on top of my rad so I keep an eye on it. I have 1700 miles with flap off never had a problem yet. If there is deep powder to ride in along any trail I'm usually there , not actually on the trail so I've played enough in the deep snow to see the difference from stock when I got it new ,tunnel would be covered in ice everywhere and now the build up is like every other sled. no ice at all.
- Nov 1, 2009
- 2009 Phazer RTX
Weapon X said:My sled has never overheated once I have a temp sticker on top of my rad so I keep an eye on it. I have 1700 miles with flap off never had a problem yet. If there is deep powder to ride in along any trail I'm usually there , not actually on the trail so I've played enough in the deep snow to see the difference from stock when I got it new ,tunnel would be covered in ice everywhere and now the build up is like every other sled. no ice at all.
That makes sense off trail vs on trail. It is colder in Winnipeg then it is here in Ontario. In westport i think most of maniac's riding would be on trail, right?
maniac
yes mostly on trail and lakes thanks everyone think i will buy the kit
Ultrafrozen
- Feb 14, 2010
- Ontario, Canada
- Yamaha SR Viper
martin63092 said:... buy the kit straight from yamaha it comes with extra heat protective thing, ask your dealer
^^^^X2
I did mine, broke three rivet guns on the front four rivets but it looks good.
spike337
I have the OEM Yamaha kit on mine. It comes with all the heat shields. I just had the dealer install because i heard the directions stunk and i was lazy. No more ice!
maniac
thats good to know how does it look and about how much is it
spike337
I think around $80.00 in the states.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Did my own with a 12" X 24" (I think) piece of aluminum "snagged" from work and rivited it on with an air riviter in about 15 minutes, done- no instructions needed. $80 rip off....
Still have the side plastic on as well for looks, been fine. No buildup.
- 16K
