SledFreak
- Feb 7, 2005
- Ontario. Canada
With all the talk on Studding, do we need to install Tunnel Protectors for the new Apex models.
POWERHAULIC
I believe they have the same arrangement as the RX, 1" aluminum all mounted
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Another perk with Yamaha, they provide it knowing many will stud
SledFreak
- Feb 7, 2005
- Ontario. Canada
So, those protectors are good for 1.325" stud.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I ran 1.325 megabites in both my RX-1 and Warrior with the stock tunnel protectors with zero issuesRotax! said:So, those protectors are good for 1.325" stud.
Yamahnator
I ran 1.375. You're all set Rotax.
My buddy with the polaris was complaining about that. He has to install them.
Mighty, did run them all down the middle or std pattern with some in the outside belts??
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
The RX-1 had them in the outside too, the Warrior only had them up the middle.MrSled said:Mighty, did run them all down the middle or std pattern with some in the outside belts??
paulrxwarrior
My warrior was studded only down the middle, never had a problem and hook up was great.
