DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
For those getting up there in mileage you may want to check your tunnel rivets. My heat exchangers were literally hanging on by a thread. I had to replace them all.
snowdust
How many miles on your sled?
DMCTurbo
- Nov 12, 2005
19000 kmsHow many miles on your sled?
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Get that speed Demon back together Derek. You should be out on Mud lake by now trying out the new suspension
DMCTurbo
- Nov 12, 2005
C
Can't get to Mud anymore. Someone put a berm across the road.Get that speed Demon back together Derek. You should be out on Mud lake by now trying out the new suspension
0degC
- Jun 5, 2009
- Sudbury, Ontario
No way, did not know that.C
REDLINE 1
Replaced all my rivets with stainless button head Allen screws with nylock nuts.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
These rivets are the same as Japan yamaha rivets.
DMCTurbo
- Nov 12, 2005
The ones holding the heat exchangers in were aluminum. I used steel ones to replace them.These rivets are the same as Japan yamaha rivets.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
I had tried regular stainless steel rivets and mine came loose again. This time I ordered the staved ones mentioned above. Hopefully they hold longer
What button head screws are ppl using? Must protrude a lot and be a lot bigger
stgdz
- Mar 27, 2021
- Buffalo MN
Check the rear angle mount. Yes I know about the shadows
REDLINE 1
Where are you buying these?These rivets are the same as Japan yamaha rivets.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
earthling
You can buy them in canada from Applifast. $40.00 for a box of 200. I think you have to make an account. Shipping was fast.
BS01-0618 Stavex Fastener
The Avdel® Stavex® Steel Rivet is a multi-grip, high-strength breakstem fastener that is produced in both steel and stainless steel to meet assembly requirements. This blind rivet can replace several grip fasteners, thereby reducing fastener inventory and simplifying stock control. Avdel Part...
shop.applifast.com
Air riveter highly recommended.
