1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Nothing wrong with running the wedge.
Make sure it is in the driveshaft far enough so when torqued it is under the bearing and not the brake rotor.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
The one that someone got me has a flange so it will only go in so far
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Exactly. The bearing itself was still good (seals intact, well greased and spun freely).I think he means the "Ball Bearings" were good & tight most likely cuz they never spun like they were born to do
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
THats the PEFI one I’d imagine. Designed very wellThe one that someone got me has a flange so it will only go in so far
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
BOP’s also has a washer and can only go in so far
stgdz
- Mar 27, 2021
- Buffalo MN
I took a couple from my iPhone to better explain to the installer what was happening!
PM me your number or email, I will send them! Not sure how to place a video on here!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The problem is not the wedge. The problem is the rotor/bearing is cocked on the shaft/not seated properly. OR the shaft is not true ( not likely but possible). Been through brake wobble and it was MY FAULT. Still think it helps if the skid is removed from sled when removing/re installing brake rotor. It makes it a lot easier to align the brake assembly on the shaft/tunnel when tightening 3 bolts on inside of tunnel. The shaft has no tension on it with skid removed.Run your sleds with track in air and watch for any movement in your caliper/ rotor if your three mounting bolts are tight then you have a problem.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
That will crack a chassis guaranteed when you can see it like that! Horrible movement!
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Gman25...
Did you double check your shaft to see if it was true?
Could you have taken a hit & bent the shaft just a little? Amazing how little it takes to bend them.
Reason I ask is aprox 3500 & 6500 miles ago new shafts, bearings, and wedges were installed into our machines.
Shafts & Bearings purchased summer 2020.
Bearing to shaft clearance was very close. Had to be placed perfect or would not slide on. Not sure how it could go on crooked.
Wedge locked the bearing at way less than 20ftlbs.
Wedge has been locked at 40ftlbs since.
Rotor still has some float. No perceived caliper movement.
KnappAttacks method is definitely fail safe. Especially for a very low mileage shaft.
Not sure how necessary it is for a new shaft & bearing? Unless tolerances have grown since 2020?
Again, Gman25, make sure the shaft itself is not tweaked. Otherwise you'll be doing this all over again.
Excellent repair by the way!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for posting this!
Gman25
- Dec 11, 2019
- ottawa
- 2018 sidewinder ltx
1999 srx 70
1993 vmax 750
Hey fellas i installed 3 wedges on 3 winders all with new bdx axles with new caliper/ axle bearings this was the only sled that has cracked so far
Whoever posted video of your caliper moving up and down pull that immediately you will for sure find some cracking beginning. I should have shot a video of mine before pulling it apart.
Upon reassembly i will check run out with dial indicator for sure
Should have checked all three shafts when they were delivered before putting drivers on
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Sled saw no miles with wobble. It was repaired prior!Hey fellas i installed 3 wedges on 3 winders all with new bdx axles with new caliper/ axle bearings this was the only sled that has cracked so far
- 12K
