Turbo Addiction Parts Trail Turbo Manifold is Done
Basically, have to forget about the part going up, the manifold taper would have to go the opposite side.
than its pretty simple, a 2.5" pipe that passes between the steering rod and top of chaincase a flexible section and flange to turbo.
good job ted ..... :Rockon:
check this ..after 3years ...no crack...
Ted why not just make a turbo kit now? The hard part is done, no way will I spend 5K on a kit and then have to buy a 1K header to make it work. You could sell it as the no crack turbo kit and sell them like hot cakes if you keep replying and posting on here. Your reputation in build quality would sell them. Sort of wierd that you have to make a header to solve other companies problems.
I have a lot of respect for the existing comanies that are out there right now, and the best I can hope for is a small percentage of the future sales so I chose not to make a full kit at this point.
It is a numbers game, For Example, if you have 1000 sleds out there only about 50% will be modified at all and only about 20% of those sleds will ever be modified to this level, again just an example.
Being first to market with a product good or bad is the only way to survive the Cost Involved, the Johny come latleys don't stand a chance no matter the quality.
I like being a problem solver, It is what I do.
But I am coming out with a Drag Race Kit developed on my personal sled.
Ted.
You Build this yourself?
What is it made from?
I see the turbo is tilted to the right like Powderlites kit.
yes Ted I build myself.....home made kit...intercooler too..
