I installed it two years ago and it ripped right from the beginning - 15lbs - 124 mph (more than gearing was suppose to allow) on GPS and I put 1000 + miles on it until one day when I was out of race fuel/93 mix and stupidly I ran it too hard.
Rebuilt with low compression pistons.
Put it back together with all settings the same. 500 jet in the Pitot tube. Stock jetting in the carbs and a Hallman Boost controller that has 14 full turns and I have it turned in 8 turns. Rebuilt it at the end of that season and rode it 1 time and it wasn't right but put it away for the summer to work on it later.
I got into ice oval racing the next year and it sat all year and never ran it. This year I just got it out to run for a few days in Michigan. I pulled the carbs, removed all the jets, cleaned them throroughly with mini pipe cleaning tools, flushed the tank of old gas and put in a 1/2 mix of 93 non-ox and 110.
It still did the same thing as after I rebuilt it - If I put the throttle to the bar, she falls on her face and spits and pops real bad. I tried a leaner pitot to 740 and it barely helped. If I run 1/2 to 2/3 throttle it picks up fine and builds boost to a point - I can get 8 lbs on the guage (with my controller turned all the way out - if I turn it in, everything gets worse) but it feels like it is running on maybe 4 lbs. IF I go past that 2/3 rds, it spits and pops. Almost like it will build boost so far and then just give up.
I found one of the little o-rings in the top of a carb missing, replaced it, didn't help. I have the billet tee's, checked the connections and bender box for cracks, can't seem to find anything. Haven't pressure tested yet.
I was told I need to go leaner with low comp pistons but would it really make it act that bad?
My suspicion is a leak somewhere but I am curious as to what the experts think. Should I try lower mains first?
Thanks in advance for the help, I have read a lot of threads and haven't seen anything quite the same.
