Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
Had sled dealer checked over at 250 miles for loose screws, bolts, belt, coolant level, oil levels, track tension and all was good. More correctly, after tightening turbo bolts, all was good. Did add a little coolant too.
Rode 250 more miles to get to 500 mile service... back turbo bolt GONE.
That's dissapointing!
yamaha06
That sucks! When I did my turbo bolts I ended up putting some high temp gasket maker on the threads and then re-installed and torqued bolts. Went riding on the weekend and just finished checking them and they are all still tight. The Nordlock washers would be the better route but nobody in my area sells them so figured I would try this first.
RAMSOMAIR
Did he really tighten the rear bolt. It is a PITA and maybe he said screw it too much trouble, who knows?
rlbock
I agree
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
Considering I watched him do it, I'll go with "yes."Did he really tighten the rear bolt. It is a PITA and maybe he said screw it too much trouble, who knows?
indysnake1
- Jan 11, 2017
- ny
- sidewinder
how do you get to the back turbo bolt to tighten any ideas
indysnake1
- Jan 11, 2017
- ny
- sidewinder
How do you get to back turbo bolt to tighten it what tools
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
Offset box end wrench works well
There are a lot of posts on this topic, maybe ask the questions in those threads that have been started. The info is there.
