MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
I’ve been putting the miles on the SW and playing with suspension adjustments to get it to my liking. As I was going over everything to see if I had any leaks or loose clamps again, I’ve noticed some weeping coming out of the top banjo fitting on the turbo.
I’ve bleed the coolant a few times and have noticed the overflow bottle go down a few times, but it seems to be steadying out.
No antifreeze in the oil, oil level has been fine all along. Engine temps between 167-174 on 100 mile rides every time. The only thing I’ve noticed was this fitting?
Fords4life
- Dec 7, 2021
- South Dakota
Had same issue with my 2018 zr9000 sno pro, i tightened the fitting up and it still weeped for a short while then sealed up, i kept an eye on it for awhile.
