Found this today on Snowest. Hopefully standard on 2012s.
Yamaha Announces Major Options for 2011 Nytro MTX
Yamaha-exclusive 180-hp Push Turbo, MPI Supercharger systems
Yamaha announced at a press conference today at Hay Days exclusive power options for 2011 Yamaha Nytro MTX models.
A Push Turbo and MPI Supercharger system will be available through Yamaha dealers later this fall. Both systems will produce 180 horsepower and feature factory presets that eliminate user tuning.
Both the Push Turbo system and MPI Supercharger system are designed for 6,000-ft and higher elevation applications.
Both systems are priced at under $4,000 USD.
Yamaha also announced an optional rear suspension kit for the Nytro MTX that reduces the weight by approx. 25 pounds.
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
Distributed exclusively by Yamaha Genuine Parts & Accessories
MSRP: $3,995
YPAD Part Number: SMA-TURBO-00-00
Fits 2008-2011 FX Nytro MTX Models
Easy installation, only cutting required is a 2-1/4 in hole for charge tube. Turbo comes pre-assembled and mounts above tunnel in place of factory exhaust muffler.
Uses OEM style wiring connectors
180 HP on premium pump gas
8 psi boost (non-adjustable)
1-year warranty (through Push Turbo)
Available exclusively at Yamaha dealerships
For use above 6,000 ft elevation
"The Push Turbo kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
FX Nytro MTX Supercharger
by Mountain Performance Inc.
http://www.mountainperformance.com/superchargers.htm
MSRP: $3,995
YPAD Part Number: SMA-SUPER-00-00
Fits 2008-2011 FX Nytro MTX models
Uses OEM Style wiring connectors
Uses stock exhaust
6 psi boost (non adjustable)
Features fuel-only GEMS control module that is non-adjustable
1-year warranty (through MPI)
"The MPI Supercharger kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
MSRP: $3,995
MSRP: $3,995
Uses stock exhaust
thamax
This comes at a surpise that MCX doesn't have anything to do with this being how close they work with yamaha and getting sleds before anybody else. where did push turbos come from? anybody ever run this setup or see a kit yet? there site only talks about 2-stroke kits and skidon't 1200 kits.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Pretty weird that company pushturbo comes from nowhere welling an oem/yamaha turbo option from dealerships
Ridecats
mulot30th said:Pretty weird that company pushturbo comes from nowhere welling an oem/yamaha turbo option from dealerships
if you get a chance to see one in person i think the craftsmanship is very much a part of the decision - very nicely done kit and simple install. seems like legit offering for guys wanting to try out boost.
thamax
who has one or has seen this setup i know they problems with the turbo coolers cracking on the 2-strokes last year but this nytro is totally new and untested out west i bet
- Jun 28, 2004
- Clinton, Wi.
Tom posted it here so I believe it's true http://www.ty4stroke.com/viewtopic.php?t=90310
pro116
This was at hayday's.
I have the Yamaha catalog in front of me with a the turbo and supercharger kit's.
pro116
It was Yamaha's major announcment at Hay Days
This is legit. Tom posted about it last week.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Thanks for helping me out guys.
RIKMAN
tmk50
No intercooler on the SC kit? - lower boost so maybe they won't have IC's on either kit?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Is there a turbo kit in the catalog?
pro116
Yes a a push turbo kit and a a supercharger kit by mpi.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
Link with all performance accessories: http://www.yamaha-motor.com/sport/acces ... all/1.aspx
