Turbo phazer fuel controller?
kennyspec
stonewall, manitoba
Canada
nytro
just picked up a 07 mtn lite and enjoy it a lot. Its just a bit underpowered. Was thinking of installing a turbo kit but the only thing stopping me was the fuel managment side of things. Not looking to go crazy with it just want about 100-110hp. I am very famillar with turbo setups and tuning FI. (have a 06 chev cobalt converted to turbo making over 400hp)
So far people seem to like the RB3 over the PCIII. What is everyones thoughts on here? I like the idea of the RB3 being load based with a MAP sensor and not just using a TPS vs rpm chart. Also i will be using the sled at sea level. Does the RB3 have the abality to retard/advance timing? How much timing needs to be retarded at about 10psi?
the rapid bike will work if you control fuel only, it will not control timing. The PCV would also be a nice option.
stock timing for now, only 5psi i dont think i need to do a whole lot of it. when / if i step up the boost ill get the timing module (i think it works with the pcIII)
