Saskapex
Just picked up a boost t for my apex with a mcx 16t turbo. It seems to take a lot of clicks on dial to change boost pressure at all. Was just wondering if anybody else has one and how many clicks it takes to adjust it 1 psi? Thanks
woody69
Haven't played with mine a lot but 20 clicks gives me around 12 lbs
Saskapex
Ok thanks. Thats right about where mine is at now, just didn't know what to expect I guess.
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
Saskapex said:Ok thanks. Thats right about where mine is at now, just didn't know what to expect I guess.
I guess it depends on your base level boost.
Mine is set at a base of 7 lbs.... One click after that is 1 lbs boost added.
I have yet to go past three clicks due to no head shim
And stock head bolts.
BurrFabrication
Your wastegate controls the minimun boost pressure. Each 5 clicks is typically 1 psi
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
BurrFabrication said:Your wastegate controls the minimun boost pressure. Each 5 clicks is typically 1 psi
5 clicks…good to know. my boost gauge is small and hard to read accurately under full power so i thought i was getting
1lb in one turn but it was hard to tell…..i'll try a couple more clicks and see what happens.
