Turbo Viper secondary settings.
STAIN
Vermont
2024 Arctic Cat Riot 9000
LOCATION
Vermont
Just curious to what people are running for secondary set ups in the 190 Vipers. I am thinking a slight helix change may get me spot on but am wondering what others are running. I am trying to cure a slight over rev on the bottom and don't want to go the reflash route to raise the limiter.
My secondary is as follows... 51 -43 helix, purple spring which I believe to be an EPI 100/159 wrapped at 0-1.
I am thinking a 53R-43 will cure my initial over rev................
I run a 51/43 with a Yamaha silver (I think, Ill check tomorrow) at 6-1 or 2 depending on snow and temp.
Are you able to add weight to the heel of your weights to keep it off the rev limiter down low?
Yes, but I am getting maxed out in that area. I have tried softer springs, and actually prefer softer springs, but the sled doesn't drive like it should when I get away from this purple spring. I would REALLY like one of those new Gforce helix kits but they are a couple weeks out for the Viper application. The darn helixs are $100-125 each so to buy one to just try can get expensive. I liked the old artic Cat roller clutch when helixs were @ $25, I have a shelf full of those!!!!!
Ah, thanks Stain. Didn't realize they were going to release it for the Viper also.
I am going to move some primary weight around.....
