STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Just curious to what people are running for secondary set ups in the 190 Vipers. I am thinking a slight helix change may get me spot on but am wondering what others are running. I am trying to cure a slight over rev on the bottom and don't want to go the reflash route to raise the limiter.
My secondary is as follows... 51 -43 helix, purple spring which I believe to be an EPI 100/159 wrapped at 0-1.
I am thinking a 53R-43 will cure my initial over rev................
Studroes144
- Oct 30, 2013
Are you able to add weight to the heel of your weights to keep it off the rev limiter down low?
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I run a 51/43 with a Yamaha silver (I think, Ill check tomorrow) at 6-1 or 2 depending on snow and temp.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Yes, but I am getting maxed out in that area. I have tried softer springs, and actually prefer softer springs, but the sled doesn't drive like it should when I get away from this purple spring. I would REALLY like one of those new Gforce helix kits but they are a couple weeks out for the Viper application. The darn helixs are $100-125 each so to buy one to just try can get expensive. I liked the old artic Cat roller clutch when helixs were @ $25, I have a shelf full of those!!!!!Are you able to add weight to the heel of your weights to keep it off the rev limiter down low?
tapex_07
- Feb 15, 2009
What is this Gforce helix kit you speak of? ^^
tapex_07
- Feb 15, 2009
Ah, thanks Stain. Didn't realize they were going to release it for the Viper also.
