ranger1
After recommendations from our site, I opted to change out the stock plastic BOV for the aluminum Turbosmart TS-0203-1223 BOV (recirculating) as I am running the Hurricane, 225,240,270 stock muffler tune with Hurricane fresh air intake. When hard on the throttle then hard off the throttle should I not hear it blow off, kind of like a fluttering sound ( especially with the fresh air intake)? I hear nothing so wondering if this is normal or something wrong. If it isnt normal is there a way to check if the BOV is working. Thanks and hopefully ya'll are getting lotsa snow!!!!!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If your not running mega boost, which you are not, you're not going to hear much if anything. Its not like the old Cat 1100's with their annoying BOV sounds.
ranger1
Ok thanks !! My buddy is running the same tune and I remember hearing his blow off. Will have to ask him if he has recirculating BOV or atmospheric. Ya I dont care for the blow off noise either, just wanted to make sure everything was ok. Is there a way of confirming the BOV is working properly ? Thank youIf your not running mega boost, which you are not, you're not going to hear much if anything. Its not like the old Cat 1100's with their annoying BOV sounds.
Turboflash
- Mar 18, 2019
- Southern MN
You'd be getting a P0035 code most likely.Ok thanks !! My buddy is running the same tune and I remember hearing his blow off. Will have to ask him if he has recirculating BOV or atmospheric. Ya I dont care for the blow off noise either, just wanted to make sure everything was ok. Is there a way of confirming the BOV is working properly ? Thank you
earthling
if you don't recirculate you give up some throttle response. you may not notice, depends on how you ride.
ranger1
Ok thanks Turbo flash!! Just know that the built up pressure has to go somewhere so hopefully the BOV is opening up releasing it like it is supposed to. Didnt get any codes so thats a good sign, lolYou'd be getting a P0035 code most likely.
Turboflash
- Mar 18, 2019
- Southern MN
You'd get that code. Sensor senses intake pressure relative to throttle position. If you let off throttle suddenly and BOV doesn't function, intake pressure is too high, hence it would throw that code which is defined by Cat as: Turbo Bypass Valve Control Circuit High.Ok thanks Turbo flash!! Just know that the built up pressure has to go somewhere so hopefully the BOV is opening up releasing it like it is supposed to. Didnt get any codes so thats a good sign, lol
ranger1
Yes, I read that somewhere also. Thats why I got the recirc BOV, dont care about the blow off noise ( take it or leave it), just want to make sure it is functioning properly as if it isnt, I would imagine that pressure would be hard on something , hahaha. Thanks Earthing!if you don't recirculate you give up some throttle response. you may not notice, depends on how you ride.
ranger1
Thanks for the explanation Turboflash, that helps lots!! The main reason I changed the BOV is because at WOT I was getting two red flashes on the dash ( low temp light and oil pressure light) with the Hurricane knock protection. Couldnt find any leaks, Dave from Hurricane said that the plastic BOV is probably the culpritYou'd get that code. Sensor senses intake pressure relative to throttle position. If you let off throttle suddenly and BOV doesn't function, intake pressure is too high, hence it would throw that code which is defined by Cat as: Turbo Bypass Valve Control Circuit High.
- 38K
