uofm
He had a set up using stock weights with a 47 degree helix what is the secondary wrapped at? What primary spring?i cannot find any information on the settings. Thanks 2009 xtx also what are you putting for weights in the shoulder , middle, and tip
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
natedawgedog
- Feb 5, 2011
- DLG, Ak
everything that I have found about his setup was with drag and fly clutch weights, sorry I cant help with stock weights.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
47degreehelix Wrap at 6 & 2 stock springs 14.5 mm rollers works great
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Wasn't that with a black spring?Stone9 said:47degreehelix Wrap at 6 & 2 stock springs 14.5 mm rollers works great
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I used that set up on my RTX with the stock Y-S-Y spring.
mx1500
whats a good set up for catwalking? like bigger weights oirrrr????
canoehead
- Jan 14, 2011
- NE, Alberta
I think a Turbo would be the best set-upmx1500 said:whats a good set up for catwalking? like bigger weights oirrrr????
mx1500
k well without spending the big $$$ for a turbo ha
canoehead
- Jan 14, 2011
- NE, Alberta
Adjust your transfers in the rear of the skid. But don't use it for trail riding.
- 6K
