Turning on headlight without the engine running
islednxs
Northeast Iowa
Can someone refresh my memory on how to turn on a headlight without the engine running on a 2006 Rage..........Many thanks
Yes.
1. Ensure that red kill switch on right handlebar is pulled up into the operating position.
2. Press and hold down the lower part of the thumbwarmer switch on the right handlebar.
3. While keeping thumbwarmer pressed down, turn ignition key to the "on" (not "start") position. Keep thumbwarmer pressed, and in about 7 to 10 seconds the headlights and instrument cluster lights will come on and the tachometer needle will do one full sweep of the dial face. You can now release the thumbwarmer swirch.
I had the fun of showing my two riding buddies last week how to do it on their new 08 vectors. LaLaLa Here's a good one.. Please comment on what you think...
On our trip to Da yooper we keeped very close records of our fill-ups.. I have a 05 vector, they have the new 08s.. Mine has nearly 4,000 miles.. They have 750.. We did a total of 430 miles.. We all were within .007 gallons difference......... Yup less than one tenth of a gallon. We averaged 18.7 for the entire trip.. Some snow plowing to clean perfect trails, to riding some crappy roads... We just couldn't believe it. MM.
Paul_C said:
Yes.
This is a good idea. Is there a way to turn on the gauges, to check the days trip meter, without the key?
