ski_bum
I am installing a stage 1 clutch kit on my nytro from ulmer, I am using my stock spring on my secondary, the instructions on his website say to use holes 3 on the secondary and 6 on the helix when replacing the stock spring. Just making sure this is the same if using the stock spring! Thanks!!
ski_bum
Gotter figured! Thanks
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
No, those will not be the correct holes for your stock secondary spring. Use the holes that are listed on the clutch spec sheet in the bag with the weights.
