Ulmer header install
jeffgilbert
Newfoundland
Canada
2019 Sidewinder BTX LE
I have just installed a header from ulmer and it fit perfectly and looks great the sled has a deeper tone now. While installing it I did notice a few loose rivites and some were actually missing never installed around my heat shield which was also cracked. So if anyone has there tank off check your rivites in the tunnel around the header and the big black brace from the handlebars to the tunnel.
Can u post some pics with the heat shield reinstalled, if it's not too late.
Sorry it's all back together now never got any of the heat shield
on the black brace that goes from the steering post to the tunnel and the bottom part of the heat shield that is riveted to the tunnel
Rivets missing on one side of the brace is normal, or you can't take the brace off to remove the tank.
Yeah that's the brace, it just seems odd that the holes where all ready drilled. The paint was worn off so I put some rivites in it anyway before I reinstalled it.
Hey Jeff.
You stated the exhaust has a deeper tone. Do you have a stock muffler of aftermarket.
I have the MBRP can and after I installed the Straightline header I thought my exhaust tone sounded throatier. Sounds sweet.
Hey Jeff.
Any power gains ?? More rpms ? What did you see thanks
I have had a chance to try yet we don't have much for snow conditions I will report when I can test . I also have picked up the ignition module so I can increase the rev limiter and advance the timing
I'll report when I get a chance to ride.
I just installed the header a couple of weeks ago and just ran the sled on my stand in the shop.
I added more weight to my clutch weights assuming a power increase. I'll compare my RPMs to last years set up.
