srx70024
Allen - Any more info on the filter relocation kits for the Apex/Attak's ? If so, pictures and price ?
Much thanks.
Matt
Much thanks.
Matt
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Will have pictures and pricing available September 30 when I change oil on our Apex RTX!!
SharkAttak
is there a waiting list for this item to come or will there be plenty, great idea......
- Apr 17, 2003
- Menno, SD
- Menno, SD
There will be plenty, just doing final fitment and finalization this weekend. I will have pricing & photos available by Monday.
alaskanbowtie
great news !
I'll have one on my 07' , Outlaw will be putting it on my sled (from you) along with some other goodies from you, then sending it up north to me......I can't wait, 1 more month....yee ha
>>>Srxspec said:There will be plenty, just doing final fitment and finalization this weekend. I will have pricing & photos available by Monday.
RXL95
will this affect the warranty? I want to buy it when it comes out but warranty issues are in the back of my mind.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Should not affect the warranty at all.
- Apr 17, 2003
- Menno, SD
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
Finalized pricing and availability information as well as pictures posted here.
http://www.ty4stroke.com/viewtopic.php?t=31450
SharkAttak
LOOKS GREAT, WILL IT BE HARD TO INSTALL?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Installation should be very easy and straight forward. Of course you will need to remove the headlight & guage assembly, air box, battery & tray. After that you simply install the billet hub. Now you remove the nose cone of the sled (6 phillips screws). Remove the 12mm bolt & nut holding the rectifier. Replace the 12mm bolt with a 5/16" x 2-1/2" bolt and thread it into the threaded spacer. After that you install the other billet hub onto the end of the threaded spacer. Install the oil lines & oil filter, button it back up and you're good to go!! Detailed instructions will be provided and you can always call us with questions.
SharkAttak
Srxspec said:Installation should be very easy and straight forward. Of course you will need to remove the headlight & guage assembly, air box, battery & tray. After that you simply install the billet hub. Now you remove the nose cone of the sled (6 phillips screws). Remove the 12mm bolt & nut holding the rectifier. Replace the 12mm bolt with a 5/16" x 2-1/2" bolt and thread it into the threaded spacer. After that you install the other billet hub onto the end of the threaded spacer. Install the oil lines & oil filter, button it back up and you're good to go!! Detailed instructions will be provided and you can always call us with questions.
nice, cause i got mine all torn down right now, i think i'll keep it that way until there available so i can install, nice job, looks great will save alot of time
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
ea looks great allen,but if any of us should be so unfortunate aas to hit a tree,wow bad oil filter lol still a great idea,but trees do jump out in front of us on ocassion!!!!
NB-NYTRO
where the oil filter normally located?
