97sx700
I have a 09 Nytro RTX. I have installed the Ulmer stage 1 clutch kit with 144 studs. My issue is I dont think im hitting the right rpms. At WOT i on pull 8560 i dont think this is right. Does anyone else have this setup? And what should the rpms be? Thought i would ask before calling Alen. Plus im only get 89mph i did hit 92 once but that was and felt like the i ran the entire Turtle Flowage. Suggestions Please. Thanks Nick
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
call ulmer, he stands by his product and will help you with any questions you have.
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
Best Bet would to call Allen, the kit comes with many washers you can add to the weights. Maybe you need adjusting??
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Sounds like u need to remove some weight from the tips to get your rpm up a bit
97sx700
Thanks for you input, talked to Allen and was told to take the weight out of the tip! Should only be pulling 8600 to 8800 rpms.
