![](/styles/vip.gif)
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
These belts spin at whatever RPM, crazy stress on them, heat cycles etc... yet you can't fold it up to put it in the trunk bag. Not saying you guys are incorrect but sure find it hard to believe.
![](/styles/donate.gif)
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Me too.....I read it on gates own site. It's Pretty clear.These belts spin at whatever RPM, crazy stress on them, heat cycles etc... yet you can't fold it up to put it in the trunk bag. Not saying you guys are incorrect but sure find it hard to believe.
Search "G Force belt"
Yep, mid sized bag holds the belt in a circle.The medium bag will hold a belt nicely.
I agree but check this link outThese belts spin at whatever RPM, crazy stress on them, heat cycles etc... yet you can't fold it up to put it in the trunk bag. Not saying you guys are incorrect but sure find it hard to believe.
I have the medium bag and the belt fits snugly without folding backwards.That's what I have but the belt doesn't fit straight lengthwise. I'm really not that concerned, it's just funny I learned something new today about the belt I've been using and storing for years....lol
So far have never needed to install a spare belt so only need the spare for emergency to get home...8JP will work for that.
Hmmmmmm ...... DMC stores his belts folded up, and he does over 140 mph in the Quarter Mile. I think I'll start storing mine folded up too. Maybe I'll go faster?? Lol
Doc Harley
- Oct 17, 2016
- Here & there
I didn't know how to follow up on his comment....thanks, fleecer. Lol.Hmmmmmm ...... DMC stores his belts folded up, and he does over 140 mph in the Quarter Mile. I think I'll start storing mine folded up too. Maybe I'll go faster?? Lol
number1kyster
Another vote for Ultimax. 3,500-4,000 miles per belt on my MS16 tuned SW. 8JP would last 1,000 miles with the same clutching.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
All depends on the brand of belt and the compound. Like I said, I've seen it myself with the Dayco XTX belts, bend it backwards and the cogs break right out of it just a few years back. My bud told me that back in 2014 or so and I couldn't believe it. On the doo, you store it on the clutch guard, so it has to bend backwards a bit, just installing it on the holder would break the cogs out of it. First time I've seen it happen myself. Brand new zero mile belts mind you.
I had a new Timken Ultimax XS crack as it was held in the secondary with the spring pressure taking it off in what I would consider in a normal removal manner too. To me, the XS seems very fragile that way, so now I treat them with kid gloves installing and removing them if you know what I mean. The 8JP it seems is not fragile at all that way. Seems like some of the others are however, like the XS and the Redline.
DMCTurbo
- Nov 12, 2005
Thanks for this Bob. Good read!I agree but check this link out
DMCTurbo
- Nov 12, 2005
Lol can't wait to see how fast I can go on an unfolded belt.Hmmmmmm ...... DMC stores his belts folded up, and he does over 140 mph in the Quarter Mile. I think I'll start storing mine folded up too. Maybe I'll go faster?? Lol
DMCTurbo
- Nov 12, 2005
I truly believe the XS belt quality has diminished over the past couple years.All depends on the brand of belt and the compound. Like I said, I've seen it myself with the Dayco XTX belts, bend it backwards and the cogs break right out of it just a few years back. My bud told me that back in 2014 or so and I couldn't believe it. On the doo, you store it on the clutch guard, so it has to bend backwards a bit, just installing it on the holder would break the cogs out of it. First time I've seen it happen myself. Brand new zero mile belts mind you.
I find it a bit surprising. But looking at that sheet..
All of the below graphics basically are saying that there is a minimum curve radius around which the belt is designed to operate. It isn't about normal vs backward bends, its about minimum bend radius. The 2nd (do not crimp) and 3rd graphic images (minimum distance) are both describing minimum radius issues, but in the normal bending direction, not backwards bends (1st graphic). These belts are designed around minimum stretch fibers (carbon/kelvar/whatever) which when subjected to less than (tighter than) normal curvature is either stressing the fibers themselves or the interface between the fibers and the rest of the belt material resulting in an overall weakening of the belt.
![](/styles/TYLifeMember.gif)
Turboflash
- Mar 18, 2019
- Southern MN
Timken bought Carlisle (original maker of XS belt) in 2015. Wonder if Timken's bean counters put pressure on to reduce cost?I truly believe the XS belt quality has diminished over the past couple years.
