XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I got the updated elbow (8KC-F4376-10) for the fuel tank vent along with the clamp that it calls for. The parts are only a few bucks each. The new elbow is black and has a large opening right through it. The old red elbow has a very small opening. I used my plumbing pex crimper to crimp the clip.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Very nice,hope it helps.
errol
What’s the problem with the red one ?
XP123
- Dec 25, 2016
- Chautauqua NY
I have no idea but everybody else is finding issues with these sleds and making changes so I figured it was my turn.What’s the problem with the red one ?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Joe.....did you check the ID? I assume it must be 3/16''?
Nice work
Dan
Nice work
Dan
XP123
- Dec 25, 2016
- Chautauqua NY
I didn't check it Dan but it's the same all the way through. The red one has a very tiny hole in it and looks very restrictive. I have no real idea what the problem was with the red one but I figured for 8 bucks I would just go with the updated part.Joe.....did you check the ID? I assume it must be 3/16''?
Nice work
Dan
sledding rocks
the red one is restrictive , 3/16 is correct , the black one is not restrictive ,also currently on backorder
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yes agree...I didn't check it Dan but it's the same all the way through. The red one has a very tiny hole in it and looks very restrictive. I have no real idea what the problem was with the red one but I figured for 8 bucks I would just go with the updated part.
My stock red one was exactly 3/16" on the small end(clamped end) and the large end(into tank grommet) was stepped down, and so I drilled that end to 3/16 to fix it. So it sounds like the black updated elbow same but without that step down.
Thnx gang
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I have the red elbow and have excessive exhaust staining on my plastics and it idles low sometimes then sometimes high and sometimes good. I feel this is the culprit but has anyone else had these symptoms and replace the elbow and cure it
XP123
- Dec 25, 2016
- Chautauqua NY
I think replacing the elbow will fix most of the issues with this sled. I noticed my Winder handles better now and my clutches are cooler. Who would have thought that little elbow would have such a huge effect?I have the red elbow and have excessive exhaust staining on my plastics and it idles low sometimes then sometimes high and sometimes good. I feel this is the culprit but has anyone else had these symptoms and replace the elbow and cure it
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Yeah, it’s a little embarrassing when your $17,000 sled don’t idle right when you come to a stopI think replacing the elbow will fix most of the issues with this sled. I noticed my Winder handles better now and my clutches are cooler. Who would have thought that little elbow would have such a huge effect?
sledding rocks
LMAOI think replacing the elbow will fix most of the issues with this sled. I noticed my Winder handles better now and my clutches are cooler. Who would have thought that little elbow would have such a huge effect?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The idle symptoms you are describing could be the roll over valve malfunctioning. NO BSI have the red elbow and have excessive exhaust staining on my plastics and it idles low sometimes then sometimes high and sometimes good. I feel this is the culprit but has anyone else had these symptoms and replace the elbow and cure it
Dalton
- Mar 13, 2013
- Chippewa Falls, WI
- Sidewinder XTX SE 141
Yamaha Phazer 2007 GT
So if one has the red elbow instead of ordering the black elbow we could just drill the small end at 3/16" ? Or would it be advised just to order the black one?
Also just to ask is this something a yamaha dealer would switch out for free or is this on our own dime?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
If I was home and near dealer Id just order one like Joe did, its cheap. But likely not a warranty item.So if one has the red elbow instead of ordering the black elbow we could just drill the small end at 3/16" ? Or would it be advised just to order the black one?
Drilling is easy, but you gotta be careful....and take your time.
Dan
