Upper a arm missing bushing from factory!!!
yamamarc
Massey Ontario
Canada
2019 zr9000 Ltd
I finally had a chance to remove the upper a arm (clutch side) to inspect the excessive play/movement of the spindle!!
I discovered that both bushings in the upper a arm were never installed when built!(2019 zr9000 limited)
Next time you have your sled on a lift pull up on the ski loop to check for play! Hopefully mine was a fluke and no one else is missing them!!
Nice catch Marc I was shocked when you showed me.
Wow! I hope warranty covers the screw up Marc?
dealer is going to send me the bushings!! It's not worth the 2 hrs drive to bring sled in for 5$ in parts.
I caught it early enough so there is no damage to the frame mounts or a arm
