thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have a 12 Apex XTX and before I tear it apart was wondering if anyone remembers if it has a replaceable bearing or not it is the smooth sided upper wheel that you have to drop the suspension to get off. In fact the rear suspension bolts hold them on. I have one that has some side to side play but seems to roll very smooth. Also wondering if by chance I forgot to put a spacer back in the last time I had the suspension out because it spins so smooth. Anyone know if there is something I could have missed?
Bearings are replaceable. If you forgot the spacer on assembly you would deffinately know it.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Thank you do you or anyone know the bearing number for it?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
ttt
Capt.Storm
Glad to hear the newer ones are..on my 06 they were not.
Pretty sure the new ones i just put on have 6205 bearings.
- Jun 28, 2004
- Clinton, Wi.
I'll let you know in a little bit. My skid is out and will check and get back to you.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
6205
- Jun 28, 2004
- Clinton, Wi.
Just came in and mine both have 6205LU on the seal
