Using 2560 turbo with low boost...
tonykof
Williams MN
Looking for help on possible upgrade..
Is it worth it for me to upgrade to a 2560 turbo??
I don't plan to run anymore than 10-12 lbs, which is where I currently am..
I presently have a CPR stage I 2554 turbo..
What gains if any are to be had changing from a 2554 to a 2560. Cooler intake temps? lower header temps = less cracking? More volume = more power? (not considering any other turbos at this time, good deal on a 2560..) Again, I plan on continuing to run only 10-12 psi.
I know what the gains are at 15 psi...
Have a .08 headshim if that makes any difference, throttle is a little mushy because of the lower compression.. (I can run pump fuel at 10-12psi)
10-12Psi i dont think you want a 2560 on there map 16-18 is happy happy..
