UUUUUGGGH APEX WONT
minnesota
GOT NO CODES , FUEL PUMP RUNNING CAN HEAR IT N SEE IN TANK , HAS SPARK , GOT LIKE A WHOOOFING/KINDA POPPING NOISE OUT EXHAUST ONCE IN A WHILE OUT EXHAUST , EVEN CHANGED PLUGS
check the plugs. sounds flooded.
if you play with the throttle when you first start it with the warm up light on ,it will foul the plugs ...
