Venture battery swap
Pockets
Cohoes, NY
I looked quick and dudnt see a thread in faq but dads got a 06 venture i need to change the battery in. Is there a how to thread on here?? I know its under the air box and looks fun lol
same as rx series.... remove airbox, battery cover and your there. not too bad.
yup... 3 cyl's had one line that is a tough one, but doable. I use long nose 45 degree needle nose to help grab. not a big deal.
The way I do it is to disconnect the blow-by tube at the base of the engine and then slide it up when you remove the air box. When you reinstall the air box carefully slide the tube back down and reattach it to the base of the engine. Make sure the upper end of the tube is security attached to the air box
