dexter
So my venture won't start and I need some advice. I put my hand in front of my air intakes which worked a couple of weeks ago and she coughed, but wouldn't start. So I then put a few drops of fresh fuel in the plug holes and she fired and ran twice for about 2 seconds. What else could I do? The fuel was stabilized and I added 2 gals of fresh fuel before I started. Advice please...
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Blow into to your vent hose on the gas tank, you need to pressurize the tank.
And keep your thumb over the hose to hold the pressure while cranking it over.
dexter
thanks! ok... which one is vent hose? I see two clear hoses running at the top of the tank up and over.
It should be the one that just runs out to atmosphere to vent.
dexter
thanks sled dog... worked like a charm.
side question about carb bowl drains... I backed all of them our this morning to drain old fuel and the bolts did not go all the way flush in. In other words I can still see 3 or so threads as they just stopped and I didnt know if it looked like that when I started. so question is should the drain bolt heads be flush with the bowl? if so I dont know why mine started to fight me after such a smooth insert.
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Pull air box cover off, open throttle wide, add lil squirt of fuel in ea carb turn key, repeat as necessary till it stays running... Happens to me every fall... As far as drain screws just snug up its normal to see treads as they dont seal on threads but on the tip off the drain screw...
