langow
Was riding this week (2017 Sidewinder RTX) and started noticing a light vibration ONLY when applying brake. At times it seemed to go away, then other times come back and get very noticeable. All seemed completely normal when riding and not using the brake. No unusal noises, etc. just the vibration I could feel in my fingertips when applying brake without locking up the track. Ideas? Do I have a drive bearing going bad, or? I did feel for any excessive heat around the brake disc, but noticed nothing.
Turbomax
- Oct 31, 2021
- Ottawa
- 2018 Yamaha Sidewinder
2014 Yamaha Viper
1983 Yamaha SRV 540
Old sleds:
1999 SRX 700
2003 Yamaha Viper SX 700
2008 Yamaha Phazer
Check your driveshaft bearing.
Turboflash
- Mar 18, 2019
- Southern MN
Check trackshaft for spinning inside bearing.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Driveshaft and bearing is toast as mentioned above.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Yep, sounds like your driveshaft and bearing are toast. The rotor binds up when this happens with extreme wear, and you start to feel it pulsating when applying the brake.
langow
Ok thanks guys. Thats what I was afraid of, but hoping there was a simpler possibility.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
You are playing with fire. I had this vibration one day and felt something a day later. I opened the side panel clutch side and saw a ball bearing from drive shaft bearing laying under secondary clutch brake assembly. Caught it in time. No major damage as I caught it when it popped out. 2017 sled. 7000 miles.
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
Makes me wanna go out and buy a winder .
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Proper maintenance prevents these issues.Makes me wanna go out and buy a winder .
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I just replaced an upper shaft bearing on a 2020 Polaris with @3000 miles. Not just a sidewinder problemMakes me wanna go out and buy a winder .
Pstn head
You shouldMakes me wanna go out and buy a winder .
