Sweeper
- Jan 25, 2015
- 2015 SR Viper Ltx SE
I have a 2015 Viper. Has anyone put a adjustable riser block on there machine? If so what kind? How much is it? Do you need to extend the throttle or brake line?
Thanks Sweeper
Thanks Sweeper
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
One of my riding buds has the Rox adjustable 6-8" riser on his Viper. No issues with the throttle or brake line. I liked his set up so much that I decided to go that route on my SideWinder.
Do a quick search under "Rox" and you'll find that quite a few Viper riders like it.
alexm2816
- Mar 28, 2016
- SE Wisconsin
- 2016 SR Viper LTX-DX Turbo
I have the Rox riser vx1r is talking about. I got it used on ebay for $100 w/ quick adjust levers and a bar pad.
Aesthetically it looks really good. It eliminates the cheap cover and adds a racey look. As far as functionality it bolted in great with only a minor headache associated with cheap hardware. No line adjustments only some creative foam cutting to hide the lines under the cover.
I got it as I'm 6'2" and my dad is 5'8" and since he was brave enough to lend teenage me his toys I guess it's time to return the favor. I highly recommend the adjust levers because otherwise you may as well just get a set riser block. No shakes or shimmys in it and it hasn't moved yet. Loctite is your friend.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I'm getting the powermadd 5"-8" adjustable riser pretty soon, I'm 6'2" and do about 50/50 on off trail so I'll comment again when the white stuff gets here.
alexm2816
- Mar 28, 2016
- SE Wisconsin
Rox is 5.75-8.25 so about the same thing. I'm all arms (30" inseam) and it feels like a great height for me so I'm sure you'll like it.
Honestly I wanted the powermadd but I found a deal on 96 woody's studs, double backers, and a used rox riser + pad/cover for $150 that I couldn't say no to. Take some photos when you get it on.
Yamadog
I also have the ROX 5.75 to 8.25 on my 15 XTX and as long as you just go up and down the cables are fine. I tried rolling the bars back and did have a problem with the brake line but there is some adjustment in the banjo fitting at the caliper to get a little more play in the line. When it is fully extended up I do feel a bit of flex in the bars because the 2 sides are independent of each other and it did come loose 1 time and the bars fell backwards so check the bolts a second time after a few miles of hard riding.
