RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I was happy to see the EVO turbo kit I just out on my Viper came with thick copper gaskets.
I dont have the turbo kit, but evo mufflers Come with the copper gasket too.
i noticed that my flanges dont seal tight enough to the copper gasket.
There is definately a small leak that can be felt with your hand.
I dont like silicone sealer. In my opinion its a patch not a proper fix for exhausts.
I have about 6 of the stock gaskets so im just gonna run those till i figure something better out.
Some of those copper gaskets had too small ID also. Needed to be ground out to match pipe.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
so I pulled the muffler back apart, cleaned everything and noticed 2 spots where welding spatter were on the faces! The side that was leaking is where those small blobs of spatter were! I filed the imperfections off added high temp o2 sensor safe silicone and reinstalled the muffler. The copper gasket had a small indent where the spatter was sitting against so I lightly hammered it back flat! If anyone buys a copper reusable gasket be sure to examine the faces of the muffler and the flex pipe very carefully before install!
walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
Just took mine off last night and a small part of it was stuck to muffler.. got one on order now, did not know about the back ordered gaskets.. hopefully it doesn't take too long to get one..
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
did you order the reusable copper gasket no backorder I know of it took 2 days shipped to my doorJust took mine off last night and a small part of it was stuck to muffler.. got one on order now, did not know about the back ordered gaskets.. hopefully it doesn't take too long to get one..
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
no I ordered from Yamaha sports plaza today. I might have to order the copper one I guess
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
anyone have any luck re using the stock one?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I went threw about ten of them with 2 sleds that's why I went with the reusable onesno I ordered from Yamaha sports plaza today. I might have to order the copper one I guess
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
no but you may get lucky once or twice I've tried antiseize on a new gasket hoping I would keep it from sticking\ripping but had no luckanyone have any luck re using the stock one?
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
I got the old one on there now it stayed for the most part in one piece with no leaks currently. but the mechanic in me wants it to be perfect so I ordered the new one, I will throw that one on there once I receive it... hopefully not two months from now. or just forget it and order the copper.
olie72
- Nov 12, 2014
- Yamaha viper
Where are you guys ordering the copper gasket from, and how much are they?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I ordered mine from hurricane performance in prescot Ontario! about 30$ shippedWhere are you guys ordering the copper gasket from, and how much are they?
http://www.hurricaneperformance.ca/product/viper-copper-header-exhaust-gasket/
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I dont have any copper hanging around. Is there anything else I can make a more reusable gasket out of?
RAMSOMAIR
$27 for a stock gasket in Ontario, crazy.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
$27 for a gasket, if reusable would be ok. But for single use, terrible. Especially considering how much has to be moved to do maintenance on them. Oh well, I still love the ride!$27 for a stock gasket in Ontario, crazy.
