Viper ltx rear coupler adjustment
can you post a picture of tool to adjust it .i didn't get tools with my sled for some reason .also on my nyto the black torsion spring adjusters have a s for soft and m for medium and h for hard .its on m now .the viper ltx se doesn't have the letters on it .can it be adjusted .thank you for the help
thinnest side soft thickest side hard use a the right size socket and ratchet to turn
yes sir .i took the 2 black couplings off the shaft already .just looking on how to adjust torsion spring ones now .thanks
look underneath where the short side of the torsion spring sit on (it's a black plastic triangle) Look closely at it you will notice one side of the triangle is thinner than the other sides (the thinnest side is the softest setting the thicker part is the stiffest) use a ratchet and proper socket to turn it to desired stiffness
