WisconsinViper
- Dec 27, 2019
- Wisconsin
- Viper
I just ran my 2015 Viper LTX 140 miles for the first time this season, all was well. A few days later I went to take my sled off my tilt bed trailer. When the sled came off the trailer and hit the ground the rear suspension sagged. It compressed about half ways and stayed there. Now the sled was off the trailer and on flat ground. Without getting on the sled the suspension was still about halfway compressed. With very light weight (about 10 pounds), the rear suspension compressed all the way. If I lifted on the tunnel I could get the shocks to fully expand, but it barely holds and if I get on the sled, it would compress back down to the track. The temperature outside was around 30 degrees (warmer in the day and cooler in the nights). My first thought was that maybe some water got in the shocks and froze/thawed multiple times. I pulled the sled into the garage and heated it up to about 55 degrees. After a few hours I checked the suspension and it was better, but still compressing easier than normal. After a few days I decided to put the sled back on the trailer to take it to my local dealer. Within an hour of being back in the cold (30 ish degrees), now the suspension is back to normal. It takes a lot more weight to get the tunnel to move and it seems everything is fine. I have checked all torsion springs as well as the coil on the center shock and they are all in good shape, not cracks or breaks. I also checked all the plastic pretension adjusters and they are all in good shape as well. I have about 6,000 miles on what appears to be all original equipment (I got the sled with 4500 miles on it last year). Has anyone seen this before or have any recommendations?
