Ndsledder
- Feb 18, 2023
- North Dakota
- 2014 zr 7000 sno pro
Riding my 2014 zr 7000 sno pro and bent my bars. Has anyone ever changed bars on these sleds and if so what’s all involved particularly with the hot grips? Thanks
mike800
- Jan 20, 2022
- Anoka County, Minnesota
- 137" Catalyst
It would take more time than it is worth to mess with re-using the warmers. Order a set from RSI for Cat sleds. They work better, are higher quality and plug in.
Ndsledder
- Feb 18, 2023
- North Dakota
Thank you had feeling they couldn’t be reused. Do you happen to know where the plug in located for the hot grips? Couldn’t see any connections unless there behind the control unit.It would take more time than it is worth to mess with re-using the warmers. Order a set from RSI for Cat sleds. They work better, are higher quality and plug in.
mike800
- Jan 20, 2022
- 137" Catalyst
The connections are hidden in the control pod. Remove four torx screws to access them. I believe I used a T9 or T10.
Ndsledder
- Feb 18, 2023
- North Dakota
Ok thank you appreciate the helpThe connections are hidden in the control pod. Remove four torx screws to access them. I believe I used a T9 or T10.
RAMSOMAIR
Travis, add Barn Of parts may have a used to set with the grips already on. All you would have to do is mount the other stuff.
HighSpeedLowDrag
Just stand on a running board and grab the end of the handlebar with both hands and push it straight. They are incredibly easy to bend by hand.
Ndsledder
- Feb 18, 2023
- North Dakota
I thought about bending it back but if it bent that easy the first time be worried about bending it again or having it snap. They didn’t even bend the first time from a crash. I hit a hard sharp drift at speed and the force from that alone is what bent it.Just stand on a running board and grab the end of the handlebar with both hands and push it straight. They are incredibly easy to bend by hand.
kiddrocko
- Nov 17, 2023
- fredericton
- yamaha viper
im going to swap out my handlebars my handlebars any tips or vids would be appreciated .
Ndsledder
- Feb 18, 2023
- North Dakota
It was pretty straightforward the only thing was I only had socket style torx so needed one with some reach to take things apart. I put new heaters on the new bars but since then have switched bars and was able to use a heat gun and took the hot grips right off.im going to swap out my handlebars my handlebars any tips or vids would be appreciated .
