03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
The Vector/Apex is a different relay then the Viper, those you just updated to the solid state.Thanks. I know about the relay . Same on my vector . So will replace it. If it hasn't been done.
For the Viper/AC you will need to relocate the Fuse box out onto the belt guard, then if you have a no start in extreme cold, just open side panel and pull relay and warm up in your hand, then it will work. Happens to my buddy's 15 Viper in extreme cold, relocating the box was the solution and Travis at Barn of Parts sells a bracket for this. If you don't move it and it happens you have to do a lot of disassembly to access the relay.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
- 2013 Yamaha vector ltx
Thanks for giving me that info. I am going to look at it in the morning and will look into it more if I buy it.The Vector/Apex is a different relay then the Viper, those you just updated to the solid state.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Take the advice for the relocation of the fuse box. I had some time to kill at my cottage and decided to take the hood off to check my chain tension. This is not a job you want to do outside in the snow. The temps that day were about -10 Celsius. Trying to put the hood back on in the cold is a bear. The plastic shrinks and getting the two screw holes at the front underneath ligned up is not easy. It took about 15 minutes. If it were colder it would only be worse. On the trail all the others with you would be upset.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
Thanks just got home with and will be checking into that. Any pics of it. ThanksTake the advice for the relocation of the fuse box. I had some time to kill at my cottage and decided to take the hood off to check my chain tension. This is not a job you want to do outside in the snow. The temps that day were about -10 Celsius. Trying to put the hood back on in the cold is a bear. The plastic shrinks and getting the two screw holes at the front underneath ligned up is not easy. It took about 15 minutes. If it were colder it would only be worse. On the trail all the others with you would be upset.
Handy
- May 12, 2005
- Anola Manitoba
Go to Barn of parts website. There is a good description and installation instructions. I have ordered from Travis a couple of times and the items are always as advertised, reasonably priced and shipped promptly. Yes even to Canada
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
I'll do. ThanksGo to Barn of parts website. There is a good description and installation instructions. I have ordered from Travis a couple of times and the items are always as advertised, reasonably priced and shipped promptly. Yes even to Canada
2K cheaper for the Cat version? I wouldn't think twice going that route regardless.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
Done and home with it2K cheaper for the Cat version? I wouldn't think twice going that route regardless.
Hoping one ride with it this weekend. Thanks
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
Congrats on your new Cat, you will love the handling and engine
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
Thankyou. I live in Windsor Ont. Ca and driving 5 hours tomorrow to try it out. Will report back after weekendCongrats on your new Cat, you will love the handling and engine
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Where are you going?Thankyou. I live in Windsor Ont. Ca and driving 5 hours tomorrow to try it out. Will report back after weekend
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
Near Owen SoundWhere are you going?
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
X2 on Barn Of Parts. Travis is a straight up guy. Great to deal withGo to Barn of parts website. There is a good description and installation instructions. I have ordered from Travis a couple of times and the items are always as advertised, reasonably priced and shipped promptly. Yes even to Canada
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I just got home from doing the R.A.P. today, and there's so much snow up north it's crazy! Have fun and enjoy your new ride!!!Near Owen Sound
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
I live just down the road in Lasalle Ont. We head up to Gaylord Michigan to sled. Hope you have a great weekendThankyou. I live in Windsor Ont. Ca and driving 5 hours tomorrow to try it out. Will report back after weekend
