tipper
- Jan 8, 2019
- BC
- vk pro
Hey folks, have a 2007 vkpro 4stroke but I can't get the thing to keep running?
It has been sitting for a while so put new battery in, drained carbs new plugs etc
Got it started and it was way down on oil with the light on so topped it up. It will idle but as soon as you give any throttle it just dies. Any ideas what might be causing this? t ran really weird the last time I had it out two years backfiring and missing the would run smooth?
YukonMP
- Dec 25, 2014
- Yukon Territory
It sounds to me like this sled isn't seeing regular use so I'll start with the obvious.... Is the gas fresh? Run some Seafoam through it.
christoph
- Oct 12, 2020
- Idaho
- 2007 VK Professional
You can't just drain the carbs. You need to pull the carbs and at the very least clean the pilot and main jets. Add fresh non ethanol gas and add some seafoam to it and try it again. I bought an 07 a couple months ago and this is exactly what I did.
olypopper
- Oct 30, 2006
- Fairbanks,Alaska
- boatshopak.com
Is the carb heat on?
Bearman
- Nov 5, 2020
- NE Central Saskatchewan
- 2021 Yamaha VK Viking Professional
Although fresh fuel is #1, fuel filters are your next logical step to insure your fuel pumps are getting good fuel. Bearman
How is the throttle cable? Needs to have play or will activate the tors system
