chateaupitsie
- Nov 10, 2017
- Nunavut
- 2011 550f grand touring, 2000 440 Bearcat, 1998 340 Bearcat, 1984 Scandic 503, 1989 Safari 377, 1988 Bravo LT,1983 Everest 500, 2009 600 Polaris Switchback, 2016 VK Pro ii,
Good Day! On the VK PRO Mods of all the mods I have done the exhaust rerouting has been the best. Keeps the tunnel clear with minimal ice build up. That is at average riding conditions of -25. The wider ski skins give stability and the marginal snow kit was well .......marginal. The extra bogey wheel on each side was not sufficient to eliminate wear on the slider. So the marginal kit was a bust. I increased height of windshield with extension. Built a storage box for the rear. Installed ram GPS mounts for the SPOT and Handheld GPS. You can see in the photo a 1/4 inch drilled hole into the dash to bring heat up on the windshield because of icing. The noise from the clutch is a bother. Warm sled to drive, good on gas.
The Great White North
- Feb 20, 2022
- Alaska
- 2022 Yamaha VK Pro 2
When you dropped to the bottom mount holes…. was it as easy as taking the bolts out and jacking it up?dropped the rear suspension to the bottom mount holes for better traction in deep snow.
I was gonna try and the bolts seems weirdly stiff, looks like theres a set screw maybe. I dont have a manual to see the proper procedure.
YukonMP
- Dec 25, 2014
- Yukon Territory
Fifteen dollars for a VIP membership supports the site and access to a manual can be requested of a moderator.
- Feb 20, 2022
- Alaska
Is it downloadable? Only accessible on here? Do they have a 2022 manual already?Fifteen dollars for a VIP membership supports the site and access to a manual can be requested of a moderator.
YukonMP
- Dec 25, 2014
- Yukon Territory
I think downloadable, 2022 not likely but nothing has changed.
- 11K
