Woody255
- Apr 19, 2016
- NW ON
- Vmax4's
Hi all, my 19 Tcat with the Earth X ETZ14C battery went dead on the lake yesterday. It started, but stalled after a few minutes while idling and would not crank. We found the battery to be at 8.8v.
Thanks to SideshowBob, we swapped out the battery, but the dash indicated it was only producing 10.6v. This increased to 11.8 while riding back to the trailer, but fell back to 10.6 at idle.
There were no other symptoms. Everything else appeared to be fine.
I am assuming the voltage regulator has failed, which appears common on the 19 models. Has anyone else experienced comparable issues? Thanks.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
My 2021 had a bad regulator from new. The battery would die only at night time when the high beams and heated seat where on.
If you go in your dash options. Where the temperature is change that to voltage. You should be running 13-14 . When I turned my high beams on it would go bellow 11volts.
JMS@Yamaha
Be careful running a unit with a dead battery, we have seen that fry voltage regulators before. This may be what happened.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
Sooo if you read my post from last week i went through same issue, here is cause and effect.... mine was with a lithium ion battery that had a battery management system that shuts off when -10 c, and the voltage regulator has no where to send charge soo it dies, the other reason is if your battery is dead or disconnected... some way iinternally or just plain dead and wont accept a charge.... and you boost it... and then disconnect the booster while engines running... the voltage regulator spikes and fries as it sees it as you just disconnected battery,,, and again has no where to send charge. little pain to change but not too bad about 1 hour, in nose of sledHi all, my 19 Tcat with the Earth X ETZ14C battery went dead on the lake yesterday. It started, but stalled after a few minutes while idling and would not crank. We found the battery to be at 8.8v.
- 8K
- 8K
