Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
Is VP sled 96 safe on a Turbo Dynamic’s 290 flash? I can’t get much for octane boosters.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
If you’re just after octane boosters, you can order directly from Torco’s website. I ran 25% VP C16 with 93 last year and on re-fills during trips 8-16 oz of Torco Accelerator. ~600 miles. Plugs looked perfect when I changed them this year. TD MS 17 most days. That’s the 290 tune.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
290 is safe on pump 91..... Don't need race fuel
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
I get knock once and awhile while doing some lake pulls so was going to try better fuel.290 is safe on pump 91..... Don't need race fuel
RAMSOMAIR
Have you tested for boost leaks?
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
Last season was fine, I have not tested for leaks as of yet. Just seen some sled 96 locally for sale and wondered about it.Have you tested for boost leaks?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
What RPM you running when you get the knock?
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
8900-9000What RPM you running when you get the knock?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
8900-9000
I would take some tip weight out and spin it a little higher... 9100-9150. That will usually help with knock. Or find that 96 octane or T4 and splash a few gallons in each tank.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I went through this issue with my Winder back in the day....
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
Running dtay2 empty so would have to get different weights or go back to 8jp belt. Running xs825 now just pulled all weight from dtay2’s last night tried a couple pulls and 2 out of 5 flashed.I would take some tip weight out and spin it a little higher... 9100-9150. That will usually help with knock. Or find that 96 octane or T4 and splash a few gallons in each tank.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Is it flashing right away? Or deep into the run?
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
About 700’ into run.Is it flashing right away? Or deep into the run?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Suppose you don't have an AFR gauge on it.... I eventually tracked my issue down to a bad knock sensor....but i was getting it 60' out.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
I do but never noticed what it was reading when it happens. Will check tomorrow as I hope to go to the lake.Suppose you don't have an AFR gauge on it.... I eventually tracked my issue down to a bad knock sensor....but i was getting it 60' out.
- 12K
