happy1426
Would I be better to look for a xtx skid or do tip up rail extensions?? Anyone have a good 144 track to sell thanks
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
I may have a studded 144 track in excellent condition for sale from an 11 XTX Apex but won't know for three or four weeks it I will b selling it.
kviper
- Nov 7, 2003
- Oakfield WI
It is a 1.25" rip saw.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
eveything I have heard on the extended rails has been good you already got the newer style with ps and exup I would think it would be cheaper to add extended rails but I would shop around and see maybe you run into a deal some love the 128 most that have the 144 love itbut there are those that would rather have the 128 maybe a trade would work with the right person/sled post a classified add you never know.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
sell or trade your '11 for a '12 or newer XTX
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Track tension increases when the mono skids extended to a 144 go through the range of travel. Track must be run looser to compensate. Not a big deal since your sled has extrovert drivers.
The other thing to keep in mind is an xtx skid design and location allows for a better approach angle to help the sled get up on top of snow without trenching. If you extend a mono shock with no setback the approach angle is not improved.
Your tunnel already has the front xtx skid mount hole punched into the aluminum. You could just drill through the steel inside backer plate and transfer the outer triangle brackets to the front xtx hole.
The rear would require the xtx drop brackets or possibly relocating the stock 128 drop brackets.
I have some xtx skids here if you opt to go that route.
molicious
- Sep 23, 2010
- Barrie Ont
- 2011 Apex xtx
2010 Vector xtx
go with the 144 skid I converted a vector last year and its flat out awesome.. muffin works for ur extension. I buy one from barnofparts before they are all gone :O)
happy1426
What would be a good track to run when I go to a 144 thinking a 1.5 or so like to get away from running studs!!
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
I absolutely love my back country track on my apex xtx.What would be a good track to run when I go to a 144 thinking a 1.5 or so like to get away from running studs!!
happy1426
what size you running how do you find it for trail riding??
