Warpex?
73Satellite
ONWARD WITH PROJECT WARPEX (04 Warrior motor and components in 06 Apex chassis) only because I blew a hold in the Apex motor after overheat)
RX motor is mounted in the Apex chassis...all fit well and I am on a mission to finish the install of compenents from the RX to include carbs, wire harness, brain box, clutches, etc. I wanted to install the Yamaha fuel injection off of the apex but that would require more work than I have time for right now. One of the last BIG rides of the season leaves tomorrow.
HOWEVER, i do believe that the head off the apex will mount to the bottom end of the RX and I would be able to bypass the oil pressure switch. The reason for mounting the head would be for the cam position sensor, cams, and timing. THEN I would be able to use the Yamaha fuel injection, wire harness and brain box..etc.
AAAAAAAAAAAAAAHHHHHHHHHHHHH.......the crap we do just to sqweeze another ride in!!
I have read all technical updates since 05 and YES there is a lot of difference but not all that many. All engine specs match, just newer technology, and lighter material. Anyways, COOL HUH?
