Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Obviously it does. In the shorties the snow hits it directly.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Every long track I have had in the past would always heat up in low snow conditions. The Warrior is not an exeption. But keep in mind the light only comes on at low snow conditions. Yes Mikeb the track might hit the rails when you ride hard once in a while but it is good insurance. the only other cooler that might work is the viper mountain cooler. But there is a lot more work involved to adapt it to the Warrior. If there was a way to change the tits that come out of this cooler it could be mounted all the way to the end of the tunnel extension and probbibly avoid the tunnel protecter extensions all together.
mikeb
stinx
Mike where did you get the aluminum stock? I will be adding the rear heat exchanger to my sled within the next two weks. I too want to put some type of guard on the exchnger.
mikeb
Homedepot
stinx
Thanks Mikel
sledheadgeorge
- Apr 28, 2003
that bolt and washer that you have put on in the front of that piece will rub against the track when you put the sled in reverse. I know cause last winter I installed 2 temporarry pieces like that and thats what happened to me. Smooth it out or it will damage your track.
mikeb
done that ......
also making a clevic for the back so I can trash the long bolts
mikeb
stinx
looks good, what are the brackets you used?
mikeb
Brackets
Home made ..
Didnt find any off the shelf ones that would work
Home made ..
gnip134
I was thinking about putting this on my Rage......
I just wanted to know........does the Rear Exchanger have that bleeder screw on it?
stinx
what do you use to enlarge the holes where the crossover went? I was told these holes need to be made larger in order to get the new exhanger in.
