actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Does anyone know the part number for the 3 turbo bolts? I lost the back one and can't seem to peel it out of the micro fiche drawings.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Wondering IF that back one you lost is the same as the other 2? Maybe pull one and take it to Fastenal see if they can match it? Just a thought
actionjack
- Apr 9, 2005
I assume it is but I'd rather put a factory bolt in for a variety of reasons. I have looked through the drawings multiple times. Im sure I'm just missing it.Wondering IF that back one you lost is the same as the other 2? Maybe pull one and take it to Fastenal see if they can match it? Just a thought
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Gotcha . Maybe until you can get factory parts?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
8KC-RA236-00-00
actionjack
- Apr 9, 2005
Thanks so much. Thats hilarious I never looked in the steering sub-assembly and I hadn't yet also found that brace.8KC-RA236-00-00
SWTURBO
- Mar 22, 2016
- Sidewinderturbo
My thoughts is to run the torque bolts from the muffler in place of the hex head bolts in the turo bolts. I tried one in the back bolt and seemed to work and easier to tighten.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
steve if you have them when you ship my shocks back out to me,would you throw in a set for me,of course I will share the exspense.. thanksYou can have mine also. Nos Pro never got them to try.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
remove the turbo that's what we did lol,oh I forgot we had to remove it ha ha..i couldnt either. dont have 13 mm swivel, just swivel and socket and it was too big. got wrench on though and snugged a bit. was it tight? might have to get the right tool....
snowpunisher
- Feb 12, 2009
- Elgin, MN
- 17 sidewinder, 06 Vector
My dealer emailed me the service bulletin from cat. But I'm not sure how to share it on the forms.
CR
- Mar 5, 2007
- Bravo Transporter
I did mine on the weekend. The 6 TORX bolts were really tight. I thought the T50 was going to break. Warmed the engine up to operating temp , tried again and the bolts came out much easier. Thought I'd pass along. If you do this make sure your wear gloves!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
My muffler bolts have never been extremely tight but I have replaced the torx bolts with regular bolts and now just need nord locks for those
Last week I did find the hidden back turbo bolt rolling around under my clutch
actionjack
- Apr 9, 2005
I have my exhaust out trying to get to that back turbo bolt I was really hoping it was wedged under the canister but it's not
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
best idea I herd was trying to get a socket onto the bolt end(just the socket). Then using a Allen key into the 1/4"drive hole(or 3/8 or whatever u use). I never tried but you might want to try that if your talking about tightening turbo bolt that's hard to get atI have my exhaust out trying to get to that back turbo bolt I was really hoping it was wedged under the canister but it's not
actionjack
- Apr 9, 2005
Exactly what I'm going to try to do. Put factory flange bolt back there and Hillman in easiest hole to get to. Factory turbo bolts are hard to come by right now. Putting the T50s back in too. All of this hardware was surprisingly loose at only 43 miles.
