- Sauk Prairie, WI
- www.ty4stroke.com
Not finding anything larger than .65 OD on Fastenals website. So I said screw it. Ordered the ones Cannondale posted. Thanks for the link and info.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I got those in post #68
Stainless steel. 3/8" 0.410" 0.830" 0.090"-0.110" Rockwell C46 10 91074A[4]31 10.06
I was waiting for an appointment with them in a web cart at McMaster when I started calling. No at 2 Fastenal locations, yes at this obscure machine shop supply - great find! Full of catalogs and dusty old displays.
I have some at my shop if you need a few.
You can have mine also. Nos Pro never got them to try.I have some at my shop if you need a few.
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
My bolt was tight and it's easy to get at with the Turbo Force exhaust installed. I have 145 miles on so far.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Fastenal by me said they have the 3/8th. Inside measures 10.something ,Will that work?
- Sauk Prairie, WI
- www.ty4stroke.com
Like others have said, make sure the OD is .82 or so. The ones I got at fastenal are pretty narrow. They were .53 OD. I just ordered the ones Cannondale posted on page 5 of this thread
gtrdan24
- Nov 28, 2016
- lehigh valley pa
- 2017 Yamaha Sidewinder Btx 153 Le
NOT YET IVE BEEN CHECKING DAILYHas a recall or service bulletin been issued?
actionjack
- Apr 9, 2005
actionjack
- Apr 9, 2005
I couldn't get the bid out. I broke the bolt free with vice grips easily and I'm going to replace with hex head.if you remember my post on this in the past...I describe taking the torx bit out of the sckeet and putting into the box end of a combination wrench...in my description...there is no sacrificing of the tool though...
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
LTX-SE with 240kms - 2 missing bolts and the 3rd was finger tight.
It's at the Dealer now, and he says they're expecting the TSB tomorrow.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
347 miles never checked bolts. Checked them tonight all are tight LTX LE
Sent from my SM-G920W8 using Tapatalk
rlbock
100 miles and two bolts are loose haven't got to third yet, heat shield is cracked. Need a ball end torx bit, never seen a ball end torx.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I used a regul
why you need a Torx bit the turbo bolts that are loose are 13mm the 6 exhaust bolts need a t50 torx. I didn't use a ball end just a regular torx.100 miles and two bolts are loose haven't got to third yet, heat shield is cracked. Need a ball end torx bit, never seen a ball end torx.
actionjack
- Apr 9, 2005
Cat sells them. I heard Ulmer or Excell has them. Get a T50 socket and punch the Torx out out then use an adjustable to turn the bit.100 miles and two bolts are loose haven't got to third yet, heat shield is cracked. Need a ball end torx bit, never seen a ball end torx.
