slalomguy
- Oct 20, 2018
- Plymouth WI /Eagle River WI
- 2005 RX-1 Mtn 162, 2002 Viper 144 M-10 custom Build, 2007 Phazer Mtn Lite 151,2000 SX-R 2up conversion, 2000 V-Max 600 Dlx, 1996 V-Max 600, 1989 Ovation 340,
I have a squealing noise at idle and a slight drip on the clutch side of my 05 rx1. My guess is the waterpump. I see there is no belt but it is shaft driven. Given that would it be squealing?
Its shaft driven no belt and does it squeal when you pull the main belt off? Usually when the water pump fails it overheats.
I'm also thinking the squeal is the drive belt too tight at stand still.Its shaft driven no belt and does it squeal when you pull the main belt off? Usually when the water pump fails it overheats.
slalomguy
- Oct 20, 2018
drive belt is off so that is what has me stumped
Definitely could be the water pump..drive belt is off so that is what has me stumped
